I'll likely post this in the Other section as well, but if anyone here can help, I need it.
I picked up a well used 89 short bed, reg cab 4x4 with 318 and auto trans at a auction this weekend. The engine seems to be fine, but it's only got 1st gear (could be second) in the transmission, no reverse. Anyone know of something other than a rebuild that could be checked to make it driveable.
I checked the fluid, added a qt. , no change. A lot of wires are cut, zero maintenance for quite a while, I'm thinking it was the kids play truck the farm. If I can make it driveable, it'll help sort out and correct issues while I look for a 4BT. I'll change fluid and filter tomorrow, just don't hold out much hope that's the problem.
Thanks, RR
Thanks, RR
