Got reflash today
remot start system
Remember me, Help engine stalling?
I had my pcm and ecm reflashed today. My torque convertor was not staying locked.
The sticker says:
Reprogram PCM & ECM
Recall 799 & 8001
TSB 18-02-99 & 18-08-99
I hope they did the tsb 18-11-99 . They told me they were going to do that. I hope this
will help my transmission problem. I do notice already that it shifts different. What
product will help increase my timing. I am considering putting in 275 injectors and some
type of box. Any suggestions
Thanks
Ken
1998 1/2 24 valve 2500 automatic 3. 55 alcoa aluminum wheels
Ken,
Hope the reflash works for you, gets scary when they do that!
As far as a box to increase timing there is a bunch of them, Edge Products EZ and Edge Box, VA Box, and TST boxes with others out there. Suggest two things, first try and fine someone with a box and try theirs and do a search using the search button at the top of the page. There is volumes of stuff said about these boxes.
I have personally tried all of the above and just finished putting a TST PM3 level 9 on my rig, now it is a rocket ship. Its what I want but is not for everyone.
Take your time and try a few.
Good Luck.
[This message has been edited by Mike Vonada (edited 12-22-2000). ]
Talked to Jeff from Bully Dog,he told me they have a new box(like the VA)but this one has a boost module.
Big A
I wanted to be sure that did the tsb 18-21-99. They told me that the reflash would pick up all previous recalls and tsb's up till that point. I dont have a reason to doubt this but why did they list the tsb 18-02-99 and 18-08-99 on tthe label under the hood and not write down the 18-21-99 tsb.
Any thoughts. How can I be sure they did the 18-21-99?
Thanks
Ken
Ken,
I have the Edge Products EZ Box. It takes about 5 minutes to install and your done!!! It adds about 65 HP #ad
and advances your timing. What I like about the EZ is that it's EZ to remove if you have any warranty issues #ad
2001 Driftwood 3500 Quad Cab 4x4, Long Bed, 5. 9L HO Cummins Diesel (ETH), 6-Speed HD Manual (DEE) Loven the shift thing (Arrrrrh), 3:54, SLT+, 3. 54 Anti-Spin Axle, Camper Special Group, Trailer Tow Group, 18,000 LB 5th Wheel Hitch, Leather, Sliding Rear Window, BDs E-Brake, Rhino Liner (gray), Velvet ride shackles, cup smoothy, Power Edge box / EZ Box w/elbo, DD Stage III injectors, McLeod Dual Disk Clutch, K&N, SPA Gauges, Jardine Exhaust, 16cm turbo housing. Love the smell of diesel in the morning. Hope your watchen DC cuz every thing you see here is a big lie, Hehe.
