RankRam- I just installed the GDP 2-micron filter with the big line kit too.
The fuel pressure readings dropped about 1-2 pounds from this mod.
You may want a larger filter if you are seeing a 2 psi drop. I don't know how that's possible with a filter that has a < 1psi drop at 100 gph according to GDP website. What were your pre a post filter install readings?
CDonaldson - They also agree about the low fuel pressure out of the tank to the CP3 and it having a relationship to failure or early failure.
What is this??? That goes against everything Bosch has ever said that I've read, i. e. , 0 psi is acceptable as long as flow is adequate, 45 gph or so. You are implying that we all need higher pressure at CP than factory pump can provide. Let's not start a panick here or should we? What is the reasoning behind this. Going from 0 psi to 20,000 doesn't seem much different than 15 psi to 20,000. I thought flow was more critical. I don't want an aftermarket pump if not necessary. People are getting over 100,000 miles with the in-tank lift pumps. If the aftermarket pump is necessary for life of CP, injectors, added filtering, etc. , then so be it. I want the proof and then I will add one. Every year is different with injector mods, CP mods, ECM mods, etc. , so it is really hard to keep track of all this.
