I finally got around to changing over the diff oil this weekend, thanks to the tips and ideas found in the search forum of this site. Pretty easy job, although the shoulders and arms started to burn from being in awkward positions, and I had to get creative with funnels and hoses to refill the pumpkins.
Anyone else who has done this job find it difficult to find the right size socket? 13 mm "worked" for me, although it didn't seem to be the right size
Both covers came off easy, although the front definitely benefits from having the driver side jacked up a bit, especially if you dont have swivel sockets.
I used an aerosol parts cleaner to break up the grime layer inside the covers, and around the gasket face.
I applied black RTV gasket hi heat sealant to the gasket before reassembling, and slowly worked the bolts down snugly, over several times, then finally after driving a few miles.
The refilling process was tricky, because of the oil pan and spare tire are a bit in the way of allowing the squeeze bottle of oil to be held upside down. I took a short piece of rubber tubing and used it as a funnel, so that I could find a place to hold the bottle more upside down.
