So I've got the "T" and the compression fittings. Now I want to cut the Auto oil cooling line so I can install my temperature guage.
Which line do I cut? There are two lines going into the oil/water cooler on the side of the engine. Which one?
Also will a standard tubing cutter cut steel lines? Anything to watch out for?
Should I mount or brace the brass "T" in any way or will the oil line be enough to support it?
Thanks,
Bobby
2000, Driftwood, 2500, automatic, 3. 54, 2WD, LWB, SLT, Quad Cab, most of the options, Grover air horns, tow 5500lb 28'x8' Aerolite TT and two small boys.
Thanks,
Bobby
