OK, After checking for the obvious things like fuel line kinks,leaks, pre-filter screen, filter etc. .
What is the easiest way to determine if Lift Pump or IP Over-Flow Valve is bad?
I obtained fuel pressure of 10psi to an incredible 14psi WOT
I believe gauge installation is correct because I'm getting 4-5psi unloaded @55mph & 20psi WOT when I switch back to boost port.
Only symptom that lead me to check fuel pressure is a stumble @ 2200 rpm.
I would like to "pressure" you guys for an answer!
Mike
94 2500HD 5sp 4. 10LSD 4X4 RWAL w/GearVendor OD, K&N Oval w/ Pre-Filter, Straight Exhaust, Geno's Fumotovalve, AW-Direct Idle Controller, DiPricol Boost, Mag-Hytec Rear, 124K miles. NRA Member. V1.
Mike
