Put my governor spring kit and AFC kit in last night. This was alot easier than all the posts led me to believe. I had all injector lines off too for 370's install so that may have helped. I had to install one set of springs over again because the directions said to remove "THE" (I assumed 1pc) bottom seat, so I did, then installed the new seat and springs. I rotated to the other set, removed the springs and bottom keeper. Hey! wait a sec. There are two pices to the bottom keeper on this side and I only removed one from the other side. Maybe that is why the spring was soooo tight.
Let's do it again!
Just be sure to remove both pieces or you probably will have no governor at all.
Easy install, go for it.
LarryB
1972 Chinook class C with 96/215 5spd, 4/5" exh, 4"BD, MagHytec, 85gal fuel, K&N RE0880, AutoMeter, 370's, BD gov kit, BD afc kit, yada-yada-yada
www.fostertruck.com/cummins
Let's do it again!
LarryB
