govenor spring kit?
SPRAYED IN BED LINERS
DTT's New Torque Converter
my truck stock + auto trans and it will not pull past 2400 rpm, i would like to turn it up a little say 3500 rpm. or do i need to get the cam plate first? my truck runs ok untill i tow with it then it's a real pig(reminds me of one of my old trucks ... one. 5. 7 and two. 6. 2 diesel)thanks for any help!
95 club cab auto 2wd only free mod's so far
cumminsturbo95,
If it's pulling power you are after I would recommend the cam plate over the gov spring kit. The motor is really inefficient at high rpms (low fuel economy, high heat). That mod is only for quick acceleration runs.
My personal recommendation to you is to slid your stock camplate forward and slightly adjust your high idle screw.
If that is not enough, cut the stops off of the camplate and slide it farther forward. Plug your wastegate line and buy a pyro.
See what you can get for free first. Then start spending money when that is not enough.
And it will never be enough #ad
Chris
'94 2500 4x4 auto custom fuel plate, 370's, Scotty air, 4 inch exhaust, DTT's TC and VB
I would agree with Strict9, that the Fuel plate would be a better first Modification. Made a huge diffence in my truck pulling my 27' fifth wheel. There would probably be some that would advise against moving the plate to far foreward. I have the #5 TST plate in mine, 255HP up 95HP from stock, for about $300.
Good luck with what ever you try.
95-2500-ExtCab-LB-4x4-Auto-AMSoil Air Filter, Bypass Oil Filter by others, AMSOIL and Mobil Synthetics, TST 255HP and TransGO Shift kit .
Cam plate my recommendation also. Try a #8 it will give you appx 50 more hp. Should be okay on your drivetrain-watch out for lock up slippage between 1400 and 1700 rpm towing though.
1996-350 tst #5 plate, K&N air filter,Primeloc fuel filter kit,4" exhaust,Purodyne bypass oil fiter system, bigger injectors,b&m trans pan,Amsoil all around,temp gauges out the wazzo,much trans work,double tow 33' 5th wheel and 12' trailer w/motorcycle(Honda Valkyarie Interstate)Also have 1999-250-stock.
Installing Transfer-Flow 98 gal. bed tank, governor spring kit(BD), and Bill Kodalay's TC on 96 dualie.
