While I am doing my lift pump change and other maintenance items, I have the fuel filter, lift pump and such off, I noticed the governor lever could be easily adjusted now. So, I finally want to take the lever adjustment plunge, try another plate I have from the #10 thats been in there forever as well as take advantage of the added access right now.
So I am probably going to put in my custom #100 plate
and get the lever to touch it since it doesn't right now. I know it is the bottom adjustment I need to make from the two, according to the Piers Diesel site
so which way do I turn it? Can I just adjust with the screw driver, tighten the 10mm set screw a bit, lift the shutdown lever and push the throttle lever forward to see where it needs to be over and over to get it just above the bottom edge of the plate? If I set the lever about 1/4-1/2 way up the #100 ramp to where it gets flat on the plate, what can I expect from performance?
I am rusty on the lever adjustment results, can someone refresh me quickly on what some of the basics of where the lever should be on a #100 plate for example?
Obviously it depends on how far forward or backward the plate is set at on the pump, but I am going to start with around full forward and set it from there.
Thanks, Joe
Thanks, Joe
