well, it's at cummins right now, but they send it to a local shop to have them rebuilt. that's what they said needs to be done. somethings wrong with the governor or something inside. $1000-$2000 to rebuild it. i don't have that much money on me, and the 'rents aren't looking to pay much (college very shortly). i'm going to go talk to the rebuilding diesel place tomorrow and find out anything i can. i'm probably going to take the truck home too (maybe loosening up on the governor springs can get the idle down some, though i doubt it at this point).
Matt, i did nothing. it pulled a little harder than normal when running down a hill when i hit the brakes... hit it to neutral and all of a sudden i'm running at 1500rpms
it's NOT the cable or linkage, it's definately internal. the arm on the backside of the pump runs smooth, has breakover, and the idle stop is down allthe way (never touched). this came sudden, no prior warning. my mods are the typical that are on the pumps. too much pressure from the flat plate maybe?
Joe, the weight setup inside the pump you think is binding up? weld? my dad's a welder, but i don't want to take off that pump. the whole timing thing with removal and installation (especially of another maybe used pump) scares me.
if you have any suggestions, call me asap at 207-883-3812. i can call back so you don't pay for the long distance. need some help here!
searching for possibilities. .
thanks,
Tom Pulyak
