Engine/Transmission (1994 - 1998) governor springs
I believe you could start 1/2 turn above the stud. the further you click down the stud the more RPM you'll have, also higher Idle. I have the 175 [same pump] and mine is even with the top of the stud, cheap higher rpm fix,[defuel defeat] down 1/4 turn. from stock. [confusing]
Marv.
