GPS 3+ & laptop connection HELP
Cummins alert
12v Power Upgrade Questions
I can't get my garmin gps3+ to communicate with aaa map n go on my PC.
Anybody else have this problem?
Anybody else able to connect gps 3+ with ANY pc program?
(I have the combination pc/power cord. You can also get just a power cord, but then you can't get dc power when you want to hook to your pc. power cord works great.
I also have the remote antenna so I don't have to keep unit on dashboard to get max reception. )
2500qc, no leather or abs
1500 bigfoot, no auto waterheater or microwave.
[This message has been edited by ted kidd (edited 10-28-1999). ]
I can't answer your question, but I do have a question for you. Have you figured out a way to hook up the GPS III+ to the 12v power source? Mine is really hard on batteries, especially when I use the backlit option at night. Thanks.
Take a look at http://joe. mehaffey.com/ and see if they have what you are looking for. Lots of info on Garmin Units. I run mine with the 12V accessory power cable and have no problems with batteries. Good Luck!
Frank Dziurda
Carson City, Nevada
'99. 5 2500 4X4 6-Speed Quad Cab LWB 3. 54 LSD
I don't know about hooking the Garmin to the Map & Go, I do know that you hae to download the data to your PC and the program works with that. I use Delorme's gps and it really works well, comes complete with all the cables you need and is designed to work with Streets or M&G. Good luck
