I have never seen one that didnt display speed. Most units have more features than you will use even at the lower price points. If you plan on chart plotting the screen becomes an important issue, the bigger and higher resolution the better. One feature you want is the ablility to adjust smoothing. This is the number of times the unit averages your speed, position or altitude which it is calculating every second. In other words you can tell it to average or smooth over ten seconds and with your speed for example it will average your speed over 10 seconds and read the average number out. This is good because it can hop around quite a bit if you smooth on a short inverval. In fact at one second you can stay parked and the unit will continue to show you moving and changing directions because it will decide you are at a slightly different spot every time it recalculates. All GPS have this, some dont let you adjust it to suit your needs. On my boat when Im crossing the Gulf of Alaska I will run my smoothing up to 2 minutes and all they way down to 15 seconds if Im splitting cans. I would guess most any unit nowadays will be able to carry more waypoints and that sort of thing than non commercial users will use.
