Today I had a Draw Tite Gooseneck hitch put on my 2003 Ram CTD. Its uses the Draw Tite Frame plates, rails and the Removable Ball. All hardware supplied is Grade 5. The manual even states its Grade 5. Is Grade 5 strong enough, I would have used Grade 8 had I installed it. The side plates on the frame rails use only (2) 1/2" bolts per side.
If it would be safer, I would rather take the time to replace the Grade 5 with Grade 8 but I may be missing some important engineering Draw Tite did. The Hitch is rated for 30,000#
Thanks
Paul
Thanks
Paul
