GRANDMAS RAD CURE
Trailer Airbrakes
Considering Prime Loc - Any advice
Radiator build up in top cores of rad.
PUT 1/2 BOX OF ARM AND HAMMER BAKING SODA IN TOP OF RADIATOR,AFTER DRAINING FLUID,THEN PUT 1/2 BOTTLE OF WHITE VINIGER IN RAD. {{{{{{CAUTION WHILE POURING IN VINIGER KEEP FACE AWAY FROM RAD. DON'T BREATHE FUMES. )))))))THIS PROCESS WORK'S WE HAVE RUN ENGINE WITH BOTH IN IT FOR 50 MILES FLUSH OUT, REFILL WITH 1/2 ANTIFREEZE 1/2 DISTILED WATER.
Im not quite following you here machinest. How does CO2 clean out the radiator? Additionally, depending on your proportions of Baking Soda/Vinager, you are running either a strong Basic or strong Acidic solution in your radiator.
David Dressler
2001 Driftwood 3500 Quad Cab 4x4, 155 inch WB, 5. 9L HO Cummins Diesel (ETH), 6-Speed HD Manual (DEE), SLT+, 3. 55 Anti-Spin Axle, Camper Special Group, Trailer Tow Group, Leather, Sliding Rear Window, Jacob's E-Brake, Rhino Liner, VDO Vision (pyro, boost, engine oil temp. ), Weather Guard Diamond Plate Saddle Box, AND functional Halo light!
"Diesel, it's not just for breakfast!"
MEN,it's not a bomb,it will clean out your RAD. cleaner than MAC DEES counter top at the sign of the arches... ... ... ... ... ... ... ... .
GOOD RAMMING
BV YOU SHOULD BE ABLE TO FIND THEM ON THE
WILD INTERNET SOME WHERE, WE DON'T GET INTO THAT...
[This message has been edited by MACHINEST (edited 08-03-2000). ]
[This message has been edited by MACHINEST (edited 09-08-2000). ]
