so yesterday the truck felt funny driving down the road. kind of notchy and all over, not to mention sporadic, as in sometimes it would drive nice and other times it would not.
so today i crawled under the truck and started looking around. i found the left side rotor looked scored, felt it and it felt ok but i could feel some groves. mind you these are cryo slotted rotors from a. r. t. with less the 10k on them. the rotor also seemed to be closer to the knuckle on the left than the right. so i jacked up the truck and checked the wheel bearing. the bearing was tight and i could not feel or see any play at all. long story short i could not find a problem and ended up tearing the whole thing apart.
for the past week or so i have thought about modifying my hubs so that i can grease them. since i had the one side all apart and the other was not difficult i decided to just go ahead and do it.
following the example of mark, from here on tdr i started my mod. i did do things a bit differently though. first i carefully removed the seal that sits against the axle. it is possible to do without severe damage. the seal is in two pieces and mostly steel. i gently bent the out piece up evenly all the way around. then i put my smallest pry bar under it and worked the seal up.
now with the seal out i could see into the bearings. first thing i noticed is the cage on them is plastic. these are timken bearings with plastic cages. anyways i got out a 7/32 (i think) drill bit and started drilling in the same location as mark. i did not have a magnetic bit but stopped freguently to clean out the hole and lube the bit. it seemed to work, even after drilling through i could not see any metal. next i took a 1/4-28 tap applied think heavy grease, and tapped the hole. not all the way, just enough for the zerk. again it did not appear that i dropped any metal in the bearing. next i took a can of break clean and flushed the old grease out (there was not a whole lot in either bearing they where going dry). the method i used was both to spray it in where the seal was, and through the new whole. all the while turning the bearing by hand. then i turned the bearing upside down and made sure i got all the solvent out of it. i also flushed a little more brake clean through the whole while upside down.
with the old grease out and the bearing cleaned. i checked it for smoothness. the bearing did make a little noise while turning but this is normal for a clean bearing.
next i installed the zerk and started greasing. i left the seal out so i could whatch how much grease it took, which was a lot. my method was similar to that of marks. i pumped in 5 to 10 shots of grease and rotated the bearing a number of revolutions. i repeated this untill i had grease coming up between the rollers. then i would rotate the bearing to the areas where the grease looked light and add more. i did this untill the grease was evenly spread all the way around (note: i did feel a sticky spot in the bearing but only after being fully greased).
now i smoothed out the grease on the top to even it out completely, then i installed the old seal. i just tapped it in with a hammer untill it was flush. this is when i pushed grease out the other seal. i do not think this will be a problem, the seal itself is still in postion the grease just pushed around it.
with the new grease the bearing feels tighter than it did when it was new. it was tough to rotate by hand but do-able. it also felt much better with the wheel and tire on when turning by hand so i think weight might help. (note: this is compared one side to the other, one modded one stock. )
now this is where mark and i really differ. mark installed his zerk on the top. looking from inside out it would be above the axle shaft. i installed mine on the front side. from the inside out its in front of the axle shaft. i did this cause it looks easier to grease.
the largest drill bit i have is 1/2" which is not big enough to clear a grease gun fitting. so i went in with a deburring tool and a die grinder and hogged out some more material untill the grease gun could easily slip in and connect to the zerk.
after this was all done i reinstalled everything and took it for a spin. it was only a couple of miles but i did notice a few things.
first the truck feels different. i cant say exactly what but something has changed for the better. it does feel smoother when it rolling, the engine does not seem to work quite as hard when starting off from a dead stop, the steering feels like it turns a bit easier, steering also feels more stable and less sloppy, it also seems a touch quieter. as i said the truck all around does feel different and in a good way. these all could be mental tricks because i was on a test drive, more miles will tell me more.
looking in my records i found that this set of wheel bearings has 80k miles on them. most of that running big tires, and do some decent off roading. i also have been feeling a clunk/bump in the steering wheel on wavy roads. its not a side to side its up and down. i didnt notice this untill earlier this year when i replaced my steering box, shaft, bushing, and added a dss. at first i tought it was something in the steering since i had just worked on it. i checked and rechecked everything for loose parts and couldnt find anything. after doing some research tonight i think that it was actually the front left wheel bearing. there were some posts from others with almost exact symptoms, they replaced their wheel bearings and fixed the problem. so far i think i have cured those problems as wheel with new grease. as i mentioned the bearings were a little dry in my eyes but then again i like lots of lube.
we will see how much life i get out of these. as mentioned there are 80k miles on them currently. my plan is to give each bearing 3 shots of grease at every service (10k miles) i am not worried about the seal blowing out, either it is and is too late, or the seal will let the grease slip past without a problem as seems to be the case. plus three shots from a hand pump gun is not a whole lot every 10k, this is also gonna be added to my ball joint grease routine which is grease it on the ground every service, plus reguardless of when it has been greased last, if the front end is in the air for any reason the ball joints get greased. i will do the same for the wheel bearins, if the tires are in the air they will get greased while rotating before i set her down.
i am hoping that this mod will make this the last set of wheel bearings i buy for this truck. i have absolutely no plans for changing to the dynatrac hubs so this is not just a temp fix. i am curious to see how they will hold up now that they are greased really well.
