2nd Gen Non-Engine/Transmission ?grease fitting on brake housing?
Engine/Transmission (1994 - 1998) DTT Trans Question
While under the engine greasing all the "joints", I found zerk style grease fittings on top of the brake housing (just above where the brake fluid line comes in) and I never noticed them before. Am I supposed to be greasing the brake housing? I just had my brakes completely redone back in the summer and wonder if the firm installed them, because they look brand new.
Don't forget to grease the valve that keeps the headlight fluid in. You don't want that to bind up... big mess.
Sorry Dan, couldn't resist.
Wait a minute, a mess if it binds up? Seems to me since it's designed to keep the headlight fluid in... . if it binds up there should be no leak at all :confused: I'm going to have think this over whilst I grease my muffler bearings. ;)
-Scott
"Took out the distributor, too. Damn lack of proper maintenance!"
Jeeze. what a buffoon! :rolleyes:
Everyone here KNOWS these Cummins use DIRECT-FIRED plugs and don't even HAVE a distributor... ;)
CHECK THE ALTERNATOR FLUID LEVEL AS WELL.
The bleaders do look alot like grease fittings Im sure many have taken a second look :) its a safe bet if it has a little cover over it its a bleeder.
There been ""LESS INTELLIGENT"" QUESTIONS ASKED
I love the newbies that ask what the whisling sound is when they go up a hill some have even got out and inspected. :-laf
