Greasing suspension/steering?
5psi boost @ 70mph??
Help!!!
Okay, on Fritz's Oil Change website, step 16 is:
Grease the front suspension and steering components and adjust the rear brakes.
Does anyone have some walk-throughs on this? What kind of grease, where does it go, etc? If someone can tell me, I'll take some pictures while I do it, and post 'em for others.
Thanks!
You should be able to find a good chassis grease at any auto supply. I think there are only 3 grease fittings on these trucks. The two top ball joints and one on lower part of the steering box, I forget what that arm is called. They DO need to be greased. As stated somewhere else, I think they come with no grease in them. I put about 12 or 13 pumps in mine before any grease started to come out, and the grease that did come out was the same grease I was putting in. No 'old' grease was pushed out. As far as adjusting the brakes, I don't need to on mine (4 wheel disc), so someone else can help you there. Good luck!
Ron
