Engine/Transmission (1994 - 1998) Great Forum
Truck was shifting back and forth between gears. Did a search and it came back to clean tps , went home sprayed tps rod and problem has gone away. Thanks guys. Best money I ever spent on my truck was membership fees to this forum!
my truck used to do the same thing. i had to clean the tps every oil change or it would start doing it again. when i got my dtt trans installed i also had a noise filter put in. the noise filter prevents the trans from going into and out of lockup. you should look into getting one. the noise filter i have is from dtt and it was $37. i also agree with you about tdr. best $$ i spend every year.
I agree TDR is the best group of people that are always there to help. I would have sent my truck to the junk yard if not for all the advice and help we get here. Most of the troubles we all have are similar and easy to fix if you know what to look for.
