Grid heater stuck on...
How much boost DD2/EZ
Cruise Control Switch
This morning, I started the truck and let it idle for about 5 minutes. As I pulled out, I noticed that my voltage was much lower than normal. When I reached 17 mph, the voltage didnt come up, as it usually would. (cycle heaters off)
2-3 miles down the road(@ 50+ mph) they finally cycled off, just as I was looking for a place to pull over.
Is there anything that "goes" in this system that I can check first?
Would this be covered under the powertrain warranty? I'm at 75K miles.
Thanks
Eric
Originally posted by The patriot
... Is there anything that "goes" in this system that I can check first? Would this be covered under the powertrain warranty? I'm at 75K miles.
AFAIK, it is *not* covered under warranty; the relays are not part of the powertrain. The heater grids themselves *might* be.
Your problem is most likely the relays on the fender wall under the driver's side battery. DC price for a replacement set is about $70.
Mine have just started to want to fail again. This time I've ordered a couple Stancor relays that are similar and good for 100 amps continuous duty, at $15 each. It'll require a tiny bit of work to mount them, but they should fit just fine. I'm waiting for them to arrive, so I don't know more as yet.
I took my relays apart (carefully). The stud contact points inside still look good, and the contactors look good, too. But I think the springs that holds the contactors off the studs just get weak after time. And given enough time bouncing around, a bit of welding and melting happens, hastening the demise of one or both of the relays.
I *could* play with installing replacement springs (one in each relay), but I want functioning relays first, and I *won't* pay DC's price. I might still play with replacing the springs because the relays look good, otherwise. I'll post again once I have the Stancor's installed. And if I get around to playing with the springs, I'll post those results, too.
Fest3er
Thanks for the reply Neal.
Let me know how that alternative relay works out.
Eric
I got the relays yesterday, modified the OEM bracket to mount them, and installed them today. They seem to be working just fine so far. They do seem to have a louder, more satisfying 'clunk' when they engage and disengage. (It's a diesel; noise is good, right?)
See http://murent.us/dodge-heater-relay/ for a modification drawing and relay sourcing info.
Original URL: See http://home.adelphia.net/~npmrphy/relay.pdf for a modification drawing and relay sourcing info.
To repeat some of the relay sourcing info, you need two Stancor 120-902 D. C Power Contactors. I got mine from Allied Electronics, (800)433-5700, for about $15 each.
These relays stand taller, so they may have a longer throw than the OEM relays, though I haven't taken them apart to see. Time will tell if they hold up as well as, or better than, the OEM relays.
One important note: since the relays stand taller, the coil control wires are a bit tight. Be sure you dress the edge of the plate and wrap the wires in some protective medium. Plastic split-loom works nicely. A bit of inner tube would also protect the control leads.
Fester
[Edit, 2/2/2015: These relays are *still* working like new.]
Well, now that it's actually COLD out, it's been acting normally.
Thanks for the drawings Neal. I expect it to take a dump this winter. :D
Eric
BTW... who the hell is Ken?:confused:
