My Excursion has been starting fine when indoors, but now it is being parked outside and won't start. Even around 20 degrees, it wont start without a tiny shot of ether. Unable to plug it in at night. The grid heaters have not been connected because i'm not using the Dodge harness.
I'm looking for instructions on how to custom wire my grid heaters. I bought a momentary switch and an LED but do not have any relays. Can i use just one relay to hook up both grid heaters? What size relay should i use and where should i buy it? Is 10 gauge wire heavy enough to go to the grid posts or do i need something bigger?
If possible, please post pictures that will show me which wires should go to which posts. I'm looking for as much detail as possible. I'm not near my truck, my dad is trying to make it run as his daily driver so i will be passing on the information. Wondering if i should try installing a glow plug in the intake tube as well. Needs to reliably start in -20 degree weather.
Much Thanks,
Matt
Much Thanks,
Matt
