If I float it just right, or it's above 1500 or 1600rpm, or I push in the clutch it's gone, and it seems like when hot @1200rpm, just as I gently go from float to coast, it pops out of 5th. And If I put a little pressure up in the stick in 5th, I get an oscillation on the stick, unlike the smooth vibration felt when pressure is applied either up or down on the stick in all other gears(not that I would do that for any other purpose other than testing).
A local transmission shop put a bearing kit, surfaced the flywheel, and installed the replacement clutch kit in it, per the dodge "noise below 1400rpm bulletin". The shop has since gone into the t-case,rear end,and the transmission twice and assure me that all the bearing preloads are between . 000 & . 005, and the noise is more quiet, but definetly still there. If it gets hot enough it rattles the t-case shifter. I checked the bushings on the shifter, and they are in brand new condition. The new clutch also hops when I engage it in reverse & sometimes in 1st, the old one did not. 5th didn't pop out before the shop went into the transmission either.
They are not sure what oil is in it, but assured me it was overfilled.
The truck has 3. 54 gears and when I road tested it against the bulletin chart for minimum gear selection speeds, which the noise should no longer be present at or above, I got 50 instead of 30 in 4th, and 60 instead of 45 in 5th.
What frustrates me is that it seems natural to begin each gear (if your empty)between 1000 & 1200rpm, it has plenty of power at those r's, even up hill, and doesn't seem to lug at all. Well, at speeds in town, between say 35 and 50, that's in the range that it makes the most noise, and I dread having to get off the freeway. However, it shifts wonderfully, up or down.
When I talked to the shop they explained to me that the gears look brand new, and the noise is completely normal for a transmission of such size behind a cummins, and that I should stuff the boots if it's too loud for me. So I stuffed the boots with an assortment of various squishy materials, and settled on part # Owens Corning pink panther fiberglass insulation, it has the best noise dampening characteristics, even over the wifes bag of cotton balls. STILL ENTIRELY TO LOUD FOR ME!!!
I have trouble believing that dodge would have sold many trucks in 1992 with transmission's that noisy, if that is the case. I could believe that if the production date was say-1945, or it was a 1975 Kenworth log tractor! (nothing against kenworths) Furthermore, when I have towed or climbed a hill, it gets really loud, and I'm afraid something is going to break.
It may sound that I find a little humor in my dilema, however, I'm only trying to laugh a little about it, instead of using my truck for munitions testing, or flame spread analysis, especially cause I sold a perfectly good chevy td,( except for the 9 mpg)to buy this truck!
I feel as though you are my last resort, The shop had the truck for almost a month, and I've paid over 2500 bucks to get rid of the noise, and I'm terrified to either keep driving it as if nothings wrong, or take it back to the shop and possibly spend even more money, and down time, w/no result. These are the questions that I need answers to, that I can think of right now.
(1) I can hear a chatter when i lug it at 1100rpm or lower in 4th especially, and this seems normal, but a grind all the way up to 15 or 16- can this possibly be normal? And if not, any idea what to look for?
(2) As far as my shifting range, is it normal? the shop told me that I should be shifting much higher to stay out of that lug induced grinding, but that would mean starting at 1500, and winding out to over 2300 in 3rd & 4th, just trying to hold an in town speed limit, is this true?
(3) And what could possibly happen during a bearing change out, to cause 5th to suddenly start popping out in such a mysterious, inadvertent way?
(4) Could I still be having a clutch harmonic problem? This is the third one. I have the full power screw turned up, but the most boost it develops is about 25psi under "everything it's got" while loaded. Who, What#@*^><***!!!?
Any help, drawings, instructions, manuals, links, pdf's, or especially your answers would be extremely appreciated. I think my truck is beginning to control my behaivior, as I don't drive in town w/ out the radio blasting like a teenager, and w/earplugs in, and the driver (thats me) loudly saying "la-la-la-la, I can't hear any problem"!!! :{
Many thanks, I sent this directly to mysteryman as well, as I wanted to see if engineering had these sort of problems/solutions. but I'm new to this computer stuff, and I could not figure out how to specifically send this to him, and everyone else as a post. So iI sent two. Hope I haven't hurt anyones feelings. Maybe someone could help me out with that one too, but it's just fine if you don't. After you folks, I think i'ts going to be my first visit to the shrink(just kiddin). Many thanks, after weeks of researching threads and other sources, I cannot find a duplicate problem/solution. However I'm certain that if we can solve this one, it will be a invaluable thread for others. yours trully, Copperlittle! PS: other than this problem, I do absolutely love the power and economy(20mpg) of my new solid steel iron love button!!!
