It's just a big U-joint, not a CV joint. You can check it some with a long screw driver and pry it aroung a bit. If you put the axle on stands it will feel rougher if you turn the wheel by hand when the steering is hard over than it does when it is straight ahead. Could be a wheel bearing too, but you need to check the U-joint if it's a 4X4.
