grinding sound
Clean those injector tubes
rotella ELC... yes or no?
I have a slight grinding sound when I turn my truck (even if I barely turn it left or right).
I check the diff. and the oil level seemed ok. Is thier something else I should be checking or is it is LSD?
Frank
01 White, Quad Cab,Short Box ,Sport SLT+,5 speed 3. 54 Ltd-slip,4X4,line-x ,Nerf bars,fiberglass tonneau cover
back to the top. please help me with this gringing sound.
do you think D/C put enought friction modifer into the diff, or is that just how the lsd works?
Frank
I had crunching sounds that started after my nerf bars were installed. It was really bad.
I got under there last night and laid into all the bolts with a big wrench. It's down to a grind, but not nearly as bad.
Not all the bolts moved, and the ones that moved went less than 1/4 turn, but it was enough to make a difference.
You may want to try that.
Pepe (My little Mule)
2001 ETH/DEE, 3. 55LSD, Forest Green Quad Cab
Ordered 2/5/01
Arrived 2/28/01
Titled 3/2/01
Frank, have you added something new to your truck lately that could cause this grinding? If it just started grinding, maybe it's caused by the most recent installation. Maybe someone can help you pin point if the grinding is coming from the front or back of your truck.
2001, 3500, 5sp, 3. 54LS, 4x4, pyro and boost on the A-pillar, 165 watt backup lights, Thomas powered on-board air system, Grovers.
I haven't add anthing since it was new. I'am wondering if the factory added enough friction modifyer (sp?) to the diff? I'am thinking about taking it in for service.
Frank
It's not stuck in 4x4 mode is it?? Mine grinds a little on dry pavement in 4x4 turning. . .
'99 3500 Quadcab Laramie SLT with customized aluminum flatbed
B&D bombed with Jakebrake, firestone air bags; 3. 54 gears
5 speed,6X4, truck mirrors, trailer towing, and camper pkgs.
Ranger Cb with Messenger kicker; Amsoiled throughout. . .
2000 Peterbilt 379 with Cummins N14plus 500 hp
13 speed fuller, 70 inch Unibilt sleeper
American Class
The LSD could be stuck, however this problems on happens once or twice a month.
Frank
You need to add Mopars friction modifier to the differential. It is common with the dana 80 limited slip to have a ratchiting or grinding noise. That means there needs to be more friction modifier added. Easy fix!! #ad
1995 2500 5 spd US Gear 2 speed,PackBrake, bombed,big turbo, injectors CUMMINS POWER!!. 2001 ETH 3500 PackBrake, gagues,otherwise stock. 1972 "1066" International Harvester 414 ci diesel pulling tractor, big pump,turbo and injectors. Alcohol injection,BINDER POWER!! .
GONZO
