I put the studs in with the head in place a couple months ago. I called ARP because the studs hit the valve covers and they told me I could leave out the washers for the studs that go through the pedestals. They also told me to grind the studs down for enough clearance. What I found was that if I ground just enough of the stud to lose the allen head recess, along with leaving the washers out, all valve covers cleared except 1. I ground the studs slowly on my bench grinder, rotating the stud as I ground, and didn't let it get hot enough to blue the metal. The last stud that still contacted the valve cover got a little extra ground off on it while installed. The reason for leaving the washers out is that the stud nuts will contact the valve cover if left in place. You will also need to make sure the holes in the block do not have liquid in them and that the threads are clean.
Waylan
