I've got a strange thing happening with my rear axle...
I searched with no luck in finding an answer.
I noticed it about 6 months ago. While towing a small trailer and taking off around a right or left turn, there would be a little grinding noise coming from the rear of the truck. It only seemed to happen while letting out the clutch. Otherwise the truck is fine.
This past weekend I drove around quite a bit in the snow, using 4wd only on loose surfaces. I also illustrated the finer points of drifting and doughnuts to my girlfriend and her sister in 2wd and 1-2 inches of snow over ice.
I had my boxes turned to stock, as there wasn't much traction.
Now my truck makes that weird grind when turning left or right, until the clutch is fully released.
The diff is filled with the proper Mopar fluid without friction modifiers, and I have about 7k miles on the fluid. (I understand they're not required as we don't have clutch packs in our diffs)
Is this the source of the noise? Or is it something else?
