Last time I checked "Tru-Trac" didn't make a diff. for our front units. Is that not the case now?
Thanks for the information. I went to JawsGear.com and saw the listing and application and plan to call them in the morning to confirm the application and if it holds I will buy one. There is a giant difference between a true 4x4 and a three wheel which is what I have now. Thanks again. Larry
I just got off the phone with "Detroit-Eaton" and this is what I was told. The e-locker can be made to fit the application it was not designed for that housing and was not engineered to handle the torque and power of the Cummins. Further I was told there is not now and no plans are afoot for a True-Trac unit for our front axle.
I don't want an e Locker or an air locker su I guess I'm still sol.
i was looking for the small locker that goes in place of the spider gear set up. this type is not made for this axle by anyone. several companies make the full size locker. this means the ring gear must come off,and be set up again. i have used the pocket locker on several trucks in the past and they work very well. but 800 to 900 $ and take the ring gear off . is a deal breaker for me. k
