Hey everyone,
I finally got a three gauge setup (Dipricol with the dash top gauge pod) from DieselManor (EGT, Boost and Trans Temp) and have a couple of questions that weren't answered in instructions.
1. For the Boost Bolt - Should I use some form of threadlocker/sealant to attach the bolt to the engine? What about attaching the brass "boost tube fittings" to the Boost Bolt? I have read that people have used RTV sealant, but that doesn't seem like the right application.
2. While dry fitting everything together, it seems the "boost tube" is loose in the brass fittings, however it looks like there is a crush washer that will cramp down around the tube holding it in place when tightened. Is this the case?
3. I also got the cooler line with sender port. Should I use any threadlocker/sealer for this? What about for the temperature sender attaching to the port?
4. For those of you that got the Dashtop Gauge Pod, did yours come with a metal bracket to attach it to the dash? Mine didn't. But I did get some screws in the bag. I can fab one up I am pretty sure, but if there is a ready made bracket out there, I want to save myself some time.
Thanks in advance for your help, hopefully I can get everything right on the first try. My wife is even excited to see what they look like once installed.
