Guage Mounts
Texas Ram Bash
Suspension
New member 6/25/00. Looking for nice triple top of dash mount for 93. Have ISSPRO 2" Pyr, Boost, and tach to mount. Have only found doubles to date. Any suggestions?
Welcome Thunderolls
This is a great group of guys - all willing to help. I think you will enjoy and profit from their help. As to your gauge pod I got my three gauge pod from Banks at www.bankspower.com. You can find single and double pillar mounts from www.autometer.com. I am currently working on combining a single and double pillar mount into a triple for my '93. That will give me a total of 6 guage positions one more than my current five. Hope this helps.
Happy Trails
'93 Banks Power Pack, K&N air filter BD Power Injectors and "Tweaked Pump" 27lbs boost unloaded.
[This message has been edited by Bob Beauchaine (edited 06-25-2000). ]
Welcome to TDR. I use www.dieselpage.com This is Diesel Injection Service in Texas and they are a great company to deal with. I bought my 4 gauge pod from there but they also have the 3 gauge pod for Isspro sized gauges.
Matt
90 W250, 5-speed, 3. 54 gears, 16 cm2 housing, tach, pyro, and boost gauges.
[This message has been edited by Lt (edited 06-26-2000). ]
Thanks for the replies. I bought my guages from Dieselpage. Also have checked Autometer, Banks, etc. . no one apparantly carries triple in top dash or post mount for 93 Dodge. I'll build something!! Thanks again !
Thunderolls,
I have had both a 3 and 4 gauge dash mount pod for my 90 which has the same dash as your truck. I know they don't make a 3 gauge pillar mount but they have the ones that set on the dash.
Matt
Just my two cents on gauge installation:
I just completed an install of Autometer boost and pyro gauges. Location I chose on my '93 was the panel between the radio and the steering column. I had to relocate the cargo light switch, do some minor trimming and fabricate a simple alluminum panel to physically mount the gauges behind the plastic overlay. Made for a real clean installation and to boot the gauges came with a green lighting option that makes them match the dash lighting to a "tee".
good luck
93 W250 4X4
Jet Tech, you must have a 5 speed. I would have to move the cargo sw and the OD lockout sw. but I bet it looks nice in there. Im leaning toward an overhead console, I used to make them for trucks... been a few years though. . heh heh.
93 ClubCab LE, 4X4,K&N,Tweaked,4" Straight pipe w/stack,BFG 315/75R 16's
106K, 10K-GVW Springs w/GN hitch.
In addition to the Banks and Autometre mounts, you could have a look at US Gear.
Doug
91. 5 D250 5 speed, 16cm2 housing, gauges (EGT, boost, tach), BD exhaust brake (w/ 60lb springs)
