Having just installed my gauges I was hoping I could get some "typical" readings to go by as I evaluate my rig. I installed Westach guages, including a EGT/Boost combo, rear diff/transmission temp combo, and fuel pressure 1-15.
What are the typical readings I should see on each of these guages? My readings reflect a fully warmed up engine at hwy speed of approx 65
EGT: Usually around 700 degrees, sometimes higher to 800 or 900 when climbing a hill.
BOOST: Varies of course, depending on the pedal, but at 65 around 8 or so on the guage.
REAR DIFF: Around 100 to 125 degrees
transmission:
transmission:
