2nd Gen Non-Engine/Transmission Guages Dead!!!
Engine/Transmission (1994 - 1998) Leaky Fuel lines
Engine/Transmission (1994 - 1998) "Fuel low" light
My friend has a 2000 and all his guages went dead the other day. His odometer flashes then displays "no bus" soon after he starts it. He has no guages and his overhead computer also says "CCD". Any ideas? Thank You all!
Sounds like a wiring harness failure or a PCM module failure, the "no bus" showing in the spot where the odometer should be is telling you that the main connection bus to the instrument cluster is dead, check main buss connection behind the instrument cluster and i believe the other end connects to the PCM "power train control module" make sure that both are clean and tight.
