Guages
Dealer in the Washington DC area
DieselNasty said:
Where can i get the 3 guage pillar mount and guages for the cheapest price?
60psi Boost, Trans Temp, EGT
DieselNasty- You can get the 1-2-or 3 gauge pillar itself from Summit or Jegs cheapest around because they buy in serious bulk quantities, then get the gauges of your choice from either same place (summit/jegs) Try Geno's- for all- cost of gauges is dependent upon manafacturer. ( how deep are your pockets) I use the Autometer Ultralites- allthough I'm changing my boost to a Stewart Warner 100psi Boost gauge- looks the same as a Ultralite.
Just my . 02 cents... ... ..... :D
I prefer the ISSPRO Enhanced Visibility, because they light up good at night, and are easy to read. I have LED's in all my gauge lights, and they make a world of difference alone. You can check out www.dieselmanor.com... they have some sweet deals on there as well. Good luck with your choices, which ever way you go.
MMeier said:
Why Mr. Racin'Duallie, why you changing to a 100# gauge?? :-laf
Well the 35psi gauge broke the needle off 2years ago:-laf
Then I changed that one out for a 60psi gauge-
Now that one is showing a bent needle:{
Anybody want to buy some gauges?:-laf :D
Cheap?:-laf
