I got a Fluidampr during the group buy. I was being lazy and had it installed by the shop that was doing my U-joints. All was good for a week or so. Then it seemed like the dampener was less effective. I convinced myself it was in my head and kept driving. I pull up to my shop today and shut the truck off, only to hear a Crack-Ping!
I found one of the bolts holding the damper on the pavement, and two of the remaining 3 loose, one only on by 1 thread. Thank god I wasn't on the road to Tahoe tonight!
I tightened the bolts and pulled into the shop. I took off the belt, dampener and tone ring, only to discover some damage. I'm not sure i want to reinstall any of it. My tone ring has been "modified" so it moves a couple of degrees on the locating pin. So has the Fluidampr. And the pin is bent.
I'll attach some pics...
Pic 1 shows the Fluidampr where it mates with the Flywheel. The anodizing has been worn off from movement, and the holes now have threads.
Pic 2 Shows the tone ring. Elongated locating hole, and the surface is distorted.
Pic 3 Shows the locating pin coming out at an angle.
I'm at a loss as to what to do. With the elongated hole and the bent pin, there's definitely a couple of degrees timing change, and I think it's retarding the timing. The surfaces of the two parts are not flat any longer. I'll have to grind them to be flat. Plus, where's all that oil coming from? The seal is good, it seems to be leaking out from the bolt holes.
What do you think?
What do you think?
