The $500. 00 Dollar Snake Oil Can
Note I have NO affiliation with this ebay ad or the company nor manufacture of the product in this post WHATSOEVER.
$2. 99 a gallon and rising?
STOP
WASTING YOUR FUEL TODAY!
ECO 4
FUEL VAPOR PRESSURE ENHANCER
Stretch your fuel dollars with
ECO SYSTEMS Fuel Vapor Enhancer
• Reduce fuel consumption by up to 20%
• Lower overall maintenance costs
• Reduce harmful emissions
Will your RV, bus or truck pass the state emissions inspection?
Watch this short news video - Results Of The Eco System Test
http://www.KVBC.com/Global/story.asp?s=3724734
and this new story out of San Antonio...
http://www.woai.com/mediacenter/?videoId=152002,565
Easy to install - NO RISK money back guarantee!
PAYS FOR ITSELF WITHIN JUST A FEW WEEKS!
About the Product
ECO SYSTEMS is a fuel vapor enhancer that increases the vapor pressure of your fuels.
What does it do? How does it work?
When the fuel passes through the unit a catalytic reaction is created, breaking up the hydrocarbon chains in the fuel. This causes the vapor pressure (ability to go from a liquid to a gas) to increase. This allows the fuel injectors or carburetor jets to make a finer "spray" of fuel directly into the combustion chamber,
creating a more complete and efficient burn of the fuel. And..... the result
is increased power and performance, lower exhaust emissions and fuel
savings.
• Lower fuel consumption
• Reduced emissions
• Increased engine power
• Less engine hesitation
When fuel burns more completely, you have lower maintenance costs due to:
• Reduced carbon buildup
• Cleaner fuel injectors
• Less carbon passing into the oil
What types of fuel does the ECO SYSTEMS work with?
ECO SYSTEMS can be used with the following fuels:
ALL INTERNAL COMBUSTION ENGINE APPLICATIONS
• Gasoline
• Propane
• Biofuels
• Diesel
• CNG
• Purinox
How is it installed?
It is installed on the fuel line between the fuel filter and the injection system.
Will it void warranties?
NO! The ECO SYSTEM will not void a manufacturer's warranty!
(Ref: Magnuson - Moss Act) U. S. Patented.
Who can use it?
• Long haul carriers - 18 Wheelers, Commercial vehicles
• Consumer vehicles - Passenger cars and trucks
• Forklifts - Gas, Propane, Diesel
• Motorcycles - Motocross, Enduro, Touring, Racing, Choppers, Harleys
• Heavy Machinery - Cranes, Loaders, Bulldozers, Skid Loaders, Farm Tractors
• Tow boats - Ski / Wakeboard boats, Tug boats
• Fishing vessels - Bass boats, Jon boats, Pontoon boats, Deep Sea
• Buses - School, City Metro, Touring, Charter, Motorhomes
Will it work on 2 cycle engines?
The systems actually work better with 2 cycle engines because it breaks down the oil as well as the gasoline. The oil, is a lubricant and is the main contributor to the exhaust emission and inefficiency of the 2 cycle engines to burn the fuel completely. The smoke of a 2 cycle will be almost eliminated and in the case of an 2 cycle outboard engine, the "oil streak" in the water will be almost eliminated. The performance increase on a 2 cycle is incredible.
What is the ECO SYSTEMS Warranty?
All units have a 90-day/100% money back guarantee. If you are dissatisfied with our product, we will refund the purchase price within 90 days of purchase. All units have a full 5-year replacement for any manufacturers defect.
Applications
The ECO SYSTEMS Fuel Vapor Enhancer will significantly decrease fuel consumption and emissions in any vehicle powered by gasoline, propane, diesel, biofuels, CNG or Purinox.
Long and short haul carriers
Save HUNDREDS of dollars each month on fuel.
Lower your overall maintenance costs.
Reduce harmful emissions.
"We experienced an average fuel savings of 15 to 28% on our long haul carriers. "
Glazier Foods - Houston, Texas
Maritime vessels
Save THOUSANDS of dollars each month on fuel.
Lengthen engine life.
"Our towboat used to use 10,000 gallons of fuel in three round trips. After we installed the Eco System units she now uses 8,000 gallons!"
Buffalo Marine Service - Houston, Texas
Construction vehicles
Reduce maintenance costs.
Save fuel.
"We were skeptical at first! We installed the Eco System on a variety of vehicles and in every instance not only did it save fuel and increase performance, it also significantly reduced smoke!"
Premier Distributing Company - Albuquerque, New Mexico
Public Works Vehicles
Improve fuel performance.
"The Eco System units we tested did everything we expected and then some! We have now equipped our entire fleet with the Eco System. "
Zavala County Sheriff's Department - Crystal City, Texas
MORE HORSEPOWER? 20% OR BETTER INCREASE IN MILAGE?
HOW COULD YOU GO WRONG?
I installed one on my pick up truck and noticed an increase in horsepower instantly. My engine starts better and burns cleaner. The true test was pulling my boat up a hill near my house. Before I installed the fuel vapor pressure enhancer I would have to downshift once just before I reached the top of the hill. Now my truck climbs it without downshifting.
I have them for motorcycles - dirtbikes to choppers - and small 4 cylinder engines all the way up to 18 wheeler and heavy machinery sizes. I used to be a trucker and you can bet that if I were still driving, there'd be one on my big rig. 20% or more increase in milage, less smoke, less wear-n-tear on my engine? I heard that!
They are simple to install and will work on any engine. Each end is threaded female. The fuel enhancer installs in the fuel line just before the carburator or fuel injection system. Installation on my truck took only 15 minutes. Three of the pictures show the ECO 2 fuel pressure enhancer on my truck's engine (Chevy 250ci. straight 6 cyl. ).
Put one of these on your engine and you will get more power, higher milage and cut down on emissions.
Client Testimonials
"Our towboat used to use 10,000 gallons of fuel in three round trips. After we installed the Eco System Units, she now uses 8,000 gallons!"
Buffalo Marine Services
"To our surprise, the overall emission levels dropped 29 - 40% after the completion of our tests. "
South Texas Community College
"They pay for themselves in a short period
of time, and then the savings is all profit. "
Trees, Inc.
15 - 28% on our long haul carriers. "
Glazier Foods
"The Eco System units we tested did everything we expected and then some! We have now equipped our entire fleet with the Eco units. "
"There were improvements in fuel economy and performance in each vehicle we tested and a significant reduction in smoke, especially at start up!"
New Mexico State Highway and Transportation Department
"We strongly believe and have proven to ourselves through years of testing that these units do lower emissions, increase performance, and lower maintenance cost on our fleet. "
San Antonio Fire Department
"We were very impressed by the reduction of smoke and increase in performance. "
Shepler's
"Our shipping container crane had a significant reduction in visible exhaust and experienced an notable increase in performance when the Eco System was installed. "
Houston Texas Port Authority
STOP
ECO 4
About the Product
savings.
• Reduced emissions
• Gasoline
• Propane
• Biofuels
• Diesel
• CNG
• Purinox
Who can use it?
Applications
Maritime vessels
Save fuel.
Client Testimonials
Trees, Inc.
Glazier Foods
Shepler's
