Can anyone tell me what they look like? I dont see them on the right side kick panel.
I'm in the middle of doing this right now... ...
I unbolted the drivers seat to get the dash to move a little more via lowering the steering column more.
I found the AB module and unplugged it. It's under the center of the dash, by the shifter (5 speed).
I also unbolted the plastic crap that's surrounding the shifter.
The box came out then, after disconnecting a few wires and vacuum hoses.
Inside the box is VERY clean for 120K miles and 10 years use. I could still see through the heater core and over 90% of the evaporator. It has a couple broken up leaves sitting at the bottom, but otherwise I'm staisfied I was doing a good job of keeping it clean. I STILL dont see where the evaporator has a leak. Dam! I sure hope the garage diagnosed this correctly.
I got the box bolted back up and sitting under the dashboard.
That vacuum line cluster in the center of the dash sure is a PITA to get too.
You really need something like Verne Troyer. Just hold him in there by his feet! You have the choice of either seeing, or feeling what youre doing, and no room for a second pair of hands. Getting the vacuum cluster back together with one hand was a challange, but I got it. #@$%!
It's now well over 90 degrees and 90% humidity. I'm done for the day.
