yes, I'm certain it's accurate... like I said, my HX40 started as an H1C... machined the compressor housing and backing plate to fit the HX40 compressor wheel, then couldn't find a 14cm wastegated or 16cm turbine housing, so I took an HX40 turbine wheel and stuck it in there making a full HX40 out of it.
Parker, the differences are the compressor wheel and compressor housing... also, most H1C's use a v-band compressor connection to the backing plate... most HX35's use a big snap ring. I prefer the v-band. much easier to work with, re-clock, etc.
honestly, if you're only looking for 450-550, I'd get it running w/ the H1C on top... like I said, you should wastegate the top at ~20psi or so. an H1C is in the heart of its map right there.
Forrest
