H2o Seperator & 2 mic fuel filter install questions
Why change a good thing
Fuel Mileage
purchased Glacier diesel duel system and now need to know on an 09 which steel fuel line is the one coming from the tank. do not want to cut into the return line. does anyone know for sure if it is the top or bottom line.
Thanks Dave
Thanks Dave
It should be the larger of the two lines. But you can follow it up to the filter and see for sure.
thanks for the reply hadnt noticed the top line was larger. where did you mount your GDP MK-2 I want to mount on outside frame rail like I did my FASS on my old 02.
my Mk is mounted underhood. . But if you look at the link in my sig you can see where I mounted my f/w sep to my frame.
Sorry I missed that link in your sig. That pretty well shows your setup. I am just adding the water sep and 2 mic filter so will be doing different. I had a FASS mounted on my old 02 and liked the position on the outside of frame rail. trying to do same with this.
Thanks for the help
Dave
