It all started with vibration at road speed. The vibration seemed to emanate from the front end, the passenger side in particular.
The passenger tire was feathered on the inside edge, the driver's side, on the outside edge. That, coupled with the miles count at nearly 77K and the vibration, had me looking at the front end.
The track bar had movement. Most, if not all, of the tie rods/tie rod ends had slack in 'em.
Wholesale replacement of front end parts. FE alignment. Tires rotated.
Vibration lessened but now it seems to be coming more from the truck's hindquarters.
Driveline inspection. The u-joint just in front of the rear axle seems to be sloppy. I take it to the neighborhood mechanic and tell him I think that u-joint might be bad.
He slides under the truck and about 1. 5 seconds later, and without touching anything, he announces, "It's shot. " Just by looking. It was that bad. So much for my mechanic'ing abilities.
Truck drives like a dream now with the new front end, SSI track bar and a good u-joint in it.
