Howdy all,
Just installed a set of the Hadley air horns(Bully) that I bought from Camping World over the weekend. MAN, WHAT A DIFFERENCE
!!!!!These horns are LOUD!I had no problems with the install,thanks to the help of other members that posted a while back about various locations for the tank,compressor,horns,etc... I mounted the tank to the left bumper brace in front of the wheelhouse liner, and the horns I put behind the bumper on a fabricated steel plate about same thickness as the crossmember. Found a nice place to nest the compressor right next to the speed control servo on top of the left fenderwell. I only had to drill one hole in the rig for the whole operation,and that was for the comp. I just disconnected the factory horns at their plugs and tapped into the horn wire under the fan shroud for the solenoid coil. This way I didn`t have to install the toggle switch that came with the kit. I am very happy with the sound and quality of the kit. I paid about $225. 00. These horns rock!!
`01 2500,QC,LB,4WD,ISB,5SPD,
355 LSD,Tow Pkg. ,Forest green PC,Mopar alum. side steps,Mopar Mud flaps,Mist gray seat covers,Tekonsha brake controller. Bone stock and plenty of power. THE BIG GREEN MACHINE.
Built in St. Louis
Phil Stuart
I`M GLAD TO BE CUMMIN`
Built in St. Louis
Phil Stuart
