Let's see if this works...
Food Network: Recipes
DQ Bourbon Pecan Pie
Recipe courtesy Paul Wayland-Smith, The Delta Queen Steamboat
Company
Recipe Summary
Prep Time: 15 minutesCook Time: 1 hour
Inactive Prep Time: 50 minutesYield: 6 to 8 servings
Flaky Pie Crust:
8 tablespoons butter, chilled
4 tablespoons vegetable shortening, chilled
1 1/2 cups flour
1 tablespoon sugar
1 teaspoon salt
5 tablespoons water, chilled with ice
Optional: Substitute 1 tablespoon cider vinegar for 1 tablespoon water
1 1/2 cups pecan halves, toasted lightly
Bourbon Pecan Pie Filling:
3 tablespoons butter
3 tablespoons bourbon
3 eggs, beaten slightly
1 cup dark corn syrup
1/2 teaspoon vanilla
2/3 cup sugar
Pinch salt
2 cups sweetened whipped cream, for garnish
Prepare flaky pie crust in advance. Cut firmly chilled butter and
shortening into small pieces. Combine the flour, sugar, and salt in the
bowl of a food processor. Pulse for 10 seconds. Add chilled shortening and
butter and pulse for about 20 seconds longer, or until the pieces of
mixture are about the size of very small peas. Add chilled water (or water
and vinegar) and mix for about 10 seconds. Do not overmix or the dough
will be tough.
Transfer to a floured cutting board and knead lightly until the mixture
forms a dough. If the mixture is already together, immediately form the
dough into a round disk about 5 inches in diameter and 1/2-inch thick.
Cover with plastic wrap and refrigerate for at least 30 minutes.
Roll out the dough on a floured surface to a diameter of about 12 inches.
Transfer the dough circle into 9-inch glass pie plate and crimp edges.
Place in refrigerator for 20 minutes. While crust is resting, preheat the
oven to 350 degrees F.
Toast pecans lightly on cookie sheet for 3 to 5 minutes. Also, cut a
parchment paper circle the size of the bottom of the pie plate.
Prick the bottom of chilled crust with fork. Just before baking crust, set
parchment paper circle on chilled dough and cover with a layer of dry
beans or rice. Bake crust for 10 minutes, until the top edge just starts
to brown. Remove beans/rice and paper and return crust to oven for about 5
minutes to lightly brown the crust bottom. If the crust edge is browning
too quickly, cover the edge with foil or turn down the temperature of the
oven to 325 degrees F. Remove crust from oven and cool.
Just before baking, make the Bourbon Pecan Pie filling: In a saucepan melt
butter, and add remaining filling ingredients, except pecans. Over a low
flame, stir filling until the mixture reaches about 100 degrees F on a
candy thermometer.
Pour heated filling into prebaked crust and arrange the pecans
decoratively on top. Bake until the filling has started to rise and a
knife inserted into the center comes out sticky but hot, about 30 to 40
minutes. The pie will not be completely set in the center at this point
but it will continue to cook a bit when out of oven. This method yields a
rich, creamy texture. Cool for at least 1 hour and serve with sweetened
whipped cream.
Episode#: DKSP01
Copyright © 2003 Television Food Network, G. P. , All Rights Reserved
Have fun! It' great! Dennis.
