I'm running Amsoil 2K 75W-90 with one fastcooler and the Geno's filter kit. I also had the SBC con OFE clutch installed in May of this year. It has somewhere in the vicinity of 8K miles on it. Sometimes I have a problem shifting into reverse when it's cold. Sometimes it shifts hard after towing when I'm trying to back my 5ver into it's nest and I have to pull forward then into reverse. It always goes in, but sometimes it's a fight. When I come to a stop, I have to "hunt" for second gear. I always get it smoothly when I try shifting to 2nd the second time. I've read a bunch of the posts on hard shifting. The shifting started to become a problem not long after I put the Series 2K lube in the transmission. I also had the clutch installed in this same general time frame. I've heard that the pilot bearing that comes with the SBC clutches are not as good as the OEM part, due to no rubber seal to hold the grease in. So is it the lube, the pilot bearing or the slave cylinder? I have heard of reports of harder shifting with the Series 2K lube. I did not have a shift problem with the factory stuff or the Amsoil 75W-90 GL4 lube. I also did not have a SBC clutch in when using those lubes, so I don't really have a good baseline to go with. Any suggestions would be appreciated. I don't want to wander from fix to fix, spending money like it's going out of style. My first inclination is to change the lube out and see what happens.
