Well decided to step down to some Mach 1. 6s so I installed them with some new connector tubes and o-rings. Got the job done left some lines loose fired it up tightened everything down checked for leaks,found none and went for a ride. Drove about 10 miles ran it up to 100mph came home got out and found fuel from the fuel neck back to the tailgate
. So today I had a sneakin hunch ol #6 didnt go in right so I pulled it and the copper washer was black around about half of it. Replaced washer and o-ring on that injector,reinstalled and no more fuel tank grenade. But now I have long crank hard start if it sits more than 5 minutes have to cycle Fass to get it light then it runs fine. I wonder if the pressure from the washer not sealing blew somthing out or ruined the o-rings on the connector tubes or what the heck I should do now. Could it have ruined the relief valve on the VP return line?
