Hello all !!
Just installed my new (well, rebuilt) VP44 from Midwest Diesel and am pretty happy, with the exception of this: Still, after the truck gets warm, it'll take about 3-5 seconds of cranking and then she'll fire up. Idles just fine, runs just fine.
This is my Ford w/99 engine. Totally stock w/the exception of FASS 150. I bought the 150 with the intention of someday adding power if I wanted. I've checked all my hoses and connections. Tight. I have a new fuel filter/strainer right after the tank before the selector valve (2 tanks), so no junk at FASS that I know of. NO codes, whereas before I'd be getting the P0216 with the old pump.
From what I've gathered, It might be that the FASS pressure is 16-17psi idle, which may be a couple over what it should be due to no fuel modifications (injectors, etc... ). New check valve too (included with new VP44). I have the new style FASS, because it only runs for a second while the grid heater is on, then comes back on after start-up.
So, question is this: is it that the pressure is too much on the VP44 after I shut her down, then re-start a half hour later and it takes the extra cranks to lower the pressure for her to fire off? Would it then make sense as to the fact that it fires right up first thing in the morning, as the pressure would have had a chance to bleed down a bit?
Sorry for the long post... . I just want to cover as much as possible for some good insight.
Thanks
Thanks
