Hi all. This is my first post.
I have been having hard starting problems with my 2000 Quad Cab 2wd for about two months. After a drive and it sits for maybe 30 minutes it may not start again for 10 to 30 minutes. It has happened about 6 times but seems to be getting more frequent.
I found a companion code by the ignition switch method so I bit the bullet and bought an AutoEnginuity scan tool. The tool pulled a p0336 code. (CKP)
Does anyone think this can be the cause of the hard starting?
I replaced the IP and installed a Raptor 150 Lift pump (Set at 15 psi at idle) about 3 months ago and have been concerned I got a bad IP and the computer on it is malfunctioning.
