Hi guys, I have a 2004.5 with 85,000 miles on it. It has started having a long crank before it would start issue. Reading the forums, I have seen that injectors or connector tubes leaking and not building up enough pressure to tell the ECM to start is a leading cause. I was getting ready to buy the tools to troubleshoot until I saw something that was odd. I have a pressure gage on top of the Filter which measures 5-6 psi when the pump is running. The lift pump was replaced with the OEM unit about 20k miles ago. When the truck starts, the pressure will slowly drop to around 3 psi and the truck will quit. The lift pump is not running. If I cycle the key and wait on the lift pump to run through a cycle, it will crank from 5 to 15 seconds and try to start again and repeat the run for a couple of seconds and die. The question that I have is what is telling the lift pump to operate? Shouldn't it be running almost continuous after the engine starts? Is there a sensor or other device that might be having an issue? One more symptom, the engine will occasionally stumble while driving for up to 5 seconds. If the engine is idling, it will die but if you are driving or giving it fuel, it will just stumble and then pick up again.
Fuel filters have been replace a couple of times. Diesel kleanz has been run through the tank when it was low on fuel and fresh fuel has been added to tank. I unplugged the FCA and the noise around the injectors immediately changed. It did not help the truck start better and it immediately through High fuel pressure codes which cleared when I reconnected FCA. Originally, there was not any CEL but there were two codes, P0107 - Map Sensor Voltage too low, and P0073 - Inlet air temp sensor voltage too high. cleared those codes and I have not seen them again.
The truck has sat a lot for the last 5 months but was used to pull a 10 to 12K triler about 50 miles when it was used. When it is running, it is strong and smooth. Any help would be appreciated.
David.
David.
