Details; '95 5.9, 300k miles, 215 injectors with about 300k miles, homemade #10 plate installed about mid point, fuel heater removed. NAPA fuel filter about 1 year old, 10k miles on it.
Truck is in south Arkansas so not cold environment at all.
No changes to the engine/fuel system this year.
Truck is in the shop, won't be able to dive into it for a few days and hoping to get thoughts of possible causes for the recent VERY hard start condition. Over the past couple months, if truck cranked every day, truck would start next day at the first hint of the engine turning over. Would start great all day.
However if left sitting for a week or so, it takes lots and lots of cranking and when it does finally start TRYING to crank it's like a gasser that's flooded with the choke engaged. Lots of missing/rough running with black smoke both once it starts trying to fire AND for the first two or three minuted of running. Have to hold accelerator down about 1/2 way to get it to start. Again, Once started no problems for the rest of the day.
Well the last couple days, the above hard start is a daily event not just if sitting for a few days. It's getting worse fast.
It is still cranking fine the rest of the day once cranked in the morning.
Preheaters are not working (working on that) however;
Outside temps don't matter, hooked up the block heater for a couple hours when it was 70 degrees outside, no difference.
I haven't replaced the return line in a few years but with all the black smoke, I'm thinking problem isn't due to a leak.
I have backed off the smoke screw (preboost screw back of afc housing) a couple turns, no diff.
Current plan it to back the preboost screw off a couple more turns. Pull the diy #10 plate and reinstall a old TST #8 plate while looking for any problems.
Anyone have thoughts on what's going on here?
Thanks for reading and any/all advice.
RonR
RonR
