I've just encountered my first problem with my truck. 2004. 5 CTD with 62,500 miles. Till now the truck has started fine whether it was 100 or 30 degrees.
When I start the truck after it has sat for several hours (ex: before or after work) it won't start the first time I crank it. After the 2nd or 3rd try it'll start, but runs rough and huffs white smoke. The truck sounds and feels like it is running on 4 cylinders. Shortly after I put it in gear and drive off it clears up. Cold start is the only thing that I see that is affected. Fuel milage is the same, oil looks fine and is at normal level & pressure. Like I said, this just started a couple of days ago and it seems to be getting worse every day.
I've done some searching around on the subject and see people mention that:
a) their trucks always did this and the dealer said it was ok, or
b) it was a bad injector(s) and did or could cause serious engine damage.
What's the best way to approach the dealer about this problem? Up to a couple of days ago my truck never did this. It appears to be getting worse though. I'll take it to the dealer, but I'd like to know what the issue is first so I don't get jerked around.
Thanks.
Thanks.
