'99 2500 2WD, auto. Lately hard starting... cranks for 7, 8 seconds and then lights off. Has always started within a 1/2 revolution until recently. (260K miles. ) Now sometimes it will light right off, sometimes not. If not, extended cranking as noted above. Then always runs great. On shutting down same scenario. Could be only two minutes between shut down and start-up: crank, crank, crank. Better when cold, but not always.
Until recently! Turned on the A/C to deal with warm weather locally - and it starts right up EVERY time as long as the A/C is on. Turn the A/C, off, and it's back to extended cranking.
Say what? Doesn't make sense! Seems to indicate an electrical problem as opposed to fuel... but how can the A/C be connected to starting?
For the record, have a reman VP44 ready to go in, have something over 100K on present VP44. First one lived for 150K +/-. Will replace fuel lift pump at same time.
Don't know what pressure existing LP is putting out, don't have a gauge. But would seem "adequate" at least, as once it's started, it does fine, even under load.
How can the A/C possibly eliminate the hard start? That's a weird one... .
Any ideas?
Any ideas?
