Hey y'all--
I've read most of the hard starting threads and didn't find a situation quite like mine.
I've had my 96 for 4 months. Bought it from a friend, so I'm sure the upgrades & repairs he told me he performed were really done.
This problem popped up in the last couple of weeks. Truck seems to run fine other than this. I'm in the Tampa area, so the truck isn't seeing really cold weather. This happens whether temps are in the 40s or the 70s. First start in the morning, or after all day at work, it cranks fine for a second, then strains to crank, like a gasser with very advanced ignition timing. It cranks slowly for a few seconds, then starts. Once I didn't drive the truck for 2-3 days and it was much worse when I started it. Starts fine after the first start, until it's sat several hours again.
If I apply some throttle, it seems to start somewhat better, and then blows white smoke. I have never used throttle when starting before, so I don't know if it would have smoked before this problem started.
My mods are in my sig. Other pertinent info: 175k on truck, 6-month-old Interstate batteries, 25-60k on the following: LarryB starter mods, lift pump, injectors, short-block rebuild.
Battery cables are stock & in good condition. All connections I've checked so far are clean and tight. Fuel return hose looks and feels very good, has probably been replaced. I drained the water separator yesterday, as I do regularly.
This is a rust-free TX truck.
I will load-test the batteries today and check the starter amp draw.
Can anyone point me in the right direction for a fix?
thanks!
kevin
thanks!
kevin
