Details here: TDR Privileges
What rpm does your truck idle at in gear with the a/c on, it should be at 850rpm. If your idle is slow it will crank alittle bit before starting, try pushing down on the gas pedal next time you start to see if it starts any faster.
Check idle rpm like nfox said. Also check your gov arm position to cam plate. Is your afc moved forward?Have you adjusted your pre-boost screw on the rear of your afc?Hope this helps.
Less than spec rack travel in the injection pump, will cause lower fueling and harder starting too. Usually a bit more than oe idle makes it happy, with a good starter and batteries.
My 97 does the same. Always a couple crank start unless I give it a bit of fuel. Turned up the idle and it starts much better. I noticed the same quick start when the gov springs were set a click tighter, too.
Winter now and set idle WAY down adn back to giving it fuel to start faster. Tight converter, winter, and fast idle don't blend well.
